Bath Tap Holes
Paul2463
Bath Tap Holes
by Paul2463 » Sat Jan 14, 2012 3:40 pm
Hello.
Sorry if this has been asked a load of times but I searched and found none of them so I thought I would ask again.
I have just ordered a new P shaped bath for my bathroom, this bath does not come with holes drilled for the taps, I have a mixer type affair at the minute with two holes drilled which feed into the body of the mixer for a single outflow. I will be using these taps with my new bath.
My questions is, after all that drivel, without having to remove the taps beforehand to find out and so I can everything at hand when it arrives, could someone please tell what size holesaw will I need to make the new holes for my bath taps?
Best Regards
plumbbob
Re: Bath Tap Holes
by plumbbob » Mon Jan 16, 2012 7:18 pm
I use a 25mm cutter.
It is currently Thu Nov 21, 2024 9:39 pm
