Is there a machine that can do the same as digging a trench
fiiido
by fiiido » Wed Jan 25, 2012 10:10 pm
I need to run utilities from the house to the back of the garden. The ideal run would be along one side of the house but that would go under a concrete floor garage.
Is there a mechanical tool that can bore the hole not only under the garage but also all the way or at least avoid digging a trench the whole way?
I can do with a smaller waste pipe if I use a saniflow system to avoifd using the large bore usual waste pipe.
I am thinkiing of the mess caused if a trench is dug. The length of the run would be 30-40metres some of it under bushes.
Thanks for any advice and if anyone can provide approx cost comparisons of the 2 options that would help.
Mandeep
Re: Is there a machine that can do the same as digging a tre
by welsh brickie » Thu Jan 26, 2012 8:14 am
you can hire a mole usually used for new water main installation.Its a hydralic ram that pushes its way through the ground.
Or you can hire a micro excavator with a 300mm bucket.
It is currently Mon Jan 20, 2025 9:04 am
