110mm soil bends -(above ground)
p2roverman
by p2roverman » Sat Jan 28, 2012 11:06 am
Does any company produce a fixed bend at 15 or 30 degree range, preferably in black, for above ground use. I prefer not to use an adjustable bend, which are only available in grey anyway.
Alternatively, I could use an orange underground pipe which are available in , though I'm told this is not advisable as the material will degrade in UV. - Comments?
(Polypipe, Osma etc only make 90 and 45 degree above ground fixed bends, but for the underground system 15 and 30 degree bends are also available).
plumbbob
Re: 110mm soil bends -(above ground)
by plumbbob » Sat Jan 28, 2012 4:18 pm
I don't know about the 15 and 30 degree bends but Floplast do the adjustable bend in black if you cannot find another answer.
p2roverman
by p2roverman » Sun Jan 29, 2012 4:50 pm
Thanks Bob, I'll have to go for this if I can't get a fixed bend. However, I'll wait to see if any one else has an answer.
It is currently Sat Jan 11, 2025 5:03 pm
