Removing Old Grout
richardsonian49
Removing Old Grout
by richardsonian49 » Fri Feb 10, 2012 11:38 am
I have to remove grout from quite a large area before regrouting.
Any ideas to make the job easier.
Re: Removing Old Grout
by welsh brickie » Sun Feb 12, 2012 2:12 pm
use a 4inch grinder with a diamond blade,It will be dusty so wear a mask.
richardsonian49
by richardsonian49 » Mon Feb 13, 2012 3:00 pm
Thanks for that
toplondonchef
by toplondonchef » Mon Feb 13, 2012 11:50 pm
Hi guys
Would just add that if using an angle grinder to remove grout, you need to be megga careful of the tiles - a fraction off line and you will be cutting into your tiles before you can correct the grinder.
The other problem is that as the discs are circular, you can't get into corners or right to the top and bottom of tiles.
In my opinion, a multi tool fitted with a diamond blade is a better option. This is less likely to damage any tiles, removes the grout really easily without filling the room with dust and due to the shape of the blade, gets into difficult areas.
These multi tools can be hired, including blades, if you don't own one / can't borrow one.
Good luck and let us know how you get on
It is currently Mon Nov 25, 2024 5:18 pm
