fixing sink to plasterboard wall
matt2675
by matt2675 » Tue Mar 13, 2007 9:21 pm
What would be the appropriate plugs and bolts/screws to use for fixing my cloakroom sink to a plasterboard wall? your help would be much apprieciated.
thedoctor
by thedoctor » Fri Mar 16, 2007 1:47 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
LEO292
by LEO292 » Thu Jul 12, 2007 10:14 pm
A tough one Matt. Choose the height you want and draw a line with a spirit level. Offer the sink up to the line and get someone to mark the screw holes through the sink which can be found at the bottom. drill the holes with a 5mm wood bit. Insert wurly fixings into the holes (these are known as metal plasterboard fixings at the builders merchants). squirt white silicone onto the back of the sink and place onto wall. Screw through the holes in the sink and silicone carefully around the sink. Leave for couple of hours and plumb in the water. Job done. Hope this helps. Leo.
It is currently Mon Jan 06, 2025 8:50 pm
