Removal of white pipe from dishwasher drainage pipe
MediumRob
by MediumRob » Thu Feb 16, 2012 3:36 pm
Hello all
This is, I hope, quite a simple query. All I want to do is remove a white pipe from the drainage pipe of a dishwasher (see attached picture to see what I am on about).
The white pipe isn't screwed-in to the drainage pipe, so unscrewing it doesn't work. I have also tried using my - above average - levels of strength to separate the pipes, also to no avail.
The only thing I can think of is to cut the drainage pipe off at the end, just below the rubber seal, but I'm pretty certain that will lead to leaks when I plumb the drainage pipe in and use the dishwasher.
Can anyone help? I would really appreciate it.
Thanks,
Rob
plumbbob
Re: Removal of white pipe from dishwasher drainage pipe
by plumbbob » Thu Feb 16, 2012 7:45 pm
As you are probably aware, the pipe should pull out and it has ridges on to prevent it from separating accidentally. If it turns freely then it is not glued in. I have come across this before where they are difficult to separate. Stick a screwdriver between the two pipes and lever them apart.
Don't cut it as it will not seal again. You will end up replacing the whole pipe.
MediumRob
by MediumRob » Thu Feb 16, 2012 10:05 pm
Thank you for replying.
Following what you said about the white pipe being removable, I tried using a screwdriver. That didn't quite work, so I sawed off the white drain pipe (close to the drainage pipe) and then managed to tug out the white pipe using some pliers.
So thanks very much for your help - much appreciated.
Rob
It is currently Fri Jan 10, 2025 11:47 am
