by plumbers1 »
Fri Jul 20, 2007 11:14 pm
Depends on if you need to use it again. But assuming you don't, get a straight connector with a rodding eys, if you need to use it again you can just remove the rodding eye. Quick solution is to put a rubber glove over the end.
