Installing a Pump
gymark2002
Installing a Pump
by gymark2002 » Wed Jul 11, 2007 12:36 pm
I am about to install a water pump to push water a shower, do I also need to install the s flange in the top of the hot water tank, or is this not nessacary?
johnb
by johnb » Tue Jul 17, 2007 11:36 am
hi mark yes but there is another way fit an ******* or surrey valve cant remember which to top outlet saves cutting all the best john
ammo
by ammo » Tue Jul 17, 2007 10:36 pm
hi mark
surrey flange in the top is easier than drilling in the side of the cylinder and fitting the ******* one. Or you can make it the first connection off the 22mm pipe from the cyllinder on the top to where it drops vertically down. But you must use a 22m tee on the horizontal piece only. And from that tee go down and the up to the loft.
ammo
It is currently Sat Nov 23, 2024 7:03 pm
