Chests of Drawers - Fixing stuck draws
8 posts   •   Page 1 of 1
tesh
by tesh » Mon Feb 27, 2012 8:54 pm
Hi Forum Members,
I have a problem with a chest of drawers. Basically the draws do not sit properly on the plastic runners and they get stuck.
How do fix this problem with out spending a fortune? I would replace with new runners however if you take a look at the pictures the current runners are plastic and the draws have grooves in them where they should sit on the runners!
Any tips useful.
Thank you.
Tesh
top
top
Side
Side
Inside Plastic Runner
Front View
Front View
tesh
Re: Chests of Drawers - Fixing stuck draws
by tesh » Tue Feb 28, 2012 4:45 pm
Just in case in one is interested I found a company that have the correct size runners and they are made of metal. I will fit these runners and stain the chest and drawers so that I can either use them in my house or sell them and get a much better price.
toptips
by toptips » Tue Feb 28, 2012 6:45 pm
Applying a bit of wax to the top of the runners might be worth a try first,the drawer that is way off level looks to be not seated on the runner correctly.Are the runners still fixed firmly to the unit?
tesh
by tesh » Fri Mar 02, 2012 8:38 pm
Thank you for your post. The plastic runners are still attached but the drawers dont stay on properly.
What sort of wax do you recommend?
tesh
by tesh » Sun Mar 04, 2012 9:26 pm
I finished the drawers.
toptips
by toptips » Fri Mar 09, 2012 7:59 am
Hi,sorry for not replying,what did you do in the end.Looks good.
tesh
by tesh » Sun Mar 11, 2012 9:29 pm
Thank you for your post, basically I removed the plastic runners and replaced them with grove runners. I used a leveler to level the runners.
diydisaster12
by diydisaster12 » Sun Oct 14, 2012 10:41 pm
Hi there,
Just moved into a rented house and have these exact same drawers! Unfortunately with the same problem too. Could you please tell me where you purchased the replacement runners from and how to fix the problem?
Thank you!
It is currently Thu Dec 26, 2024 12:34 pm
