Redring TR27 Immersion Wireing Diagram.
gotabelt
by gotabelt » Tue Mar 06, 2012 10:33 am
Can any of you bright sparks tell me where I can find a wireing diagram for this immersion heater?
Thanks in anticipation.
Peter
BLAKEY1963
Re: Redring TR27 Immersion Wireing Diagram.
by BLAKEY1963 » Tue Mar 06, 2012 7:04 pm
peter
Log on to the redring website and use the the contact us section or ring them direct.
BLAKEY1963
gotabelt
by gotabelt » Tue Mar 06, 2012 7:40 pm
Yes I have done this and beem directed to BAKA Electrics & a phone number. Thank you.
by ericmark » Wed Mar 07, 2012 3:58 am
Looking at the picture on tlc-direct web site you have three items wired in series. The element is the two posts sticking up and the neutral will connect to one of these. The other connects to the over temperature resettable thermostat which will normally have two spade terminals. The other terminal will connect to the main thermostat which normally has screw terminals. The line feed goes into the other terminal of this.
There is also an earth terminal of course.
Normally these will come pre-wired with the two links already in place.
There were two types of thermostat one for where the immersion is only form of water heating and the header tank is made from soft plastic unable to stand boiling water. These have non-resettable thermal cut-outs. There other is designed for when solid fuel water heating is also used. Because the solid fuel heating can over heat the water and cause the cut-out to trip these have re-settable cut-outs. Also the header tank is able to stand boiling water.
One has to be careful to get the right type. Main thing is material used to make header tank.
teekay
by teekay » Sat Mar 16, 2013 10:42 am
Do you still have that Redring tr27T immersion wireing diagram?
It is currently Fri Nov 22, 2024 12:32 pm
