how to stop plaster going off so quick it cracks
whiterose
by whiterose » Fri Jul 13, 2007 7:35 pm
hi there did a re skim the other day and soon as i put the plaster on the wall it went off and started cracking? :oops:
rhys
by rhys » Fri Jul 20, 2007 3:47 pm
apply pva mixed with water just before skimming a wall it will provide a key for the plaster, give you more working time and create an even suction background.
lee_007
control the suction
by lee_007 » Thu Oct 04, 2007 10:38 pm
In addition to PVA, you can also wet the wall a bit prior to plastering. The cracking is the quick loss of moisture out of the plaster. Lee
raymondo
by raymondo » Mon Oct 08, 2007 11:10 pm
i am a plasterer by trade, and the best results are by first apply a sealer coat of 1:4 pva to water, allow to dry completely then apply a tack coat of 1:2 pva to water..allow to partially dry then skim.
It is currently Tue Nov 26, 2024 3:15 am
