Fixing Cabinet to brick wall lined with 25mm Thermal Board
ALJOLSON
by ALJOLSON » Sun Jul 15, 2007 12:52 am
I need to fix a Kitchen Cabinet to a brick wall lined with 25mm Thermal board. The cabinet will be used for heavy objects like wine bottles. What size and type of screws and wall plugs must I use; I assume the screw must enter the brick for at least 50mm but cannot find a 50mm wallplug.
moger4
by moger4 » Fri Nov 13, 2009 8:45 am
you dont need a 50mm pug , you drill the hole to the depth required then insert the plug , and with the screw inserted gently tap it all the way in , the plug should always be in the brick and not the plaster or thermal borard
It is currently Mon Nov 25, 2024 12:52 am
