Why is my house so cold, even in the summer months
smoothjazz2004
by smoothjazz2004 » Mon Apr 02, 2012 8:43 pm
I live in a 3 bed detached chalet type bungalow. It has all the insulations in the walls, roof etc, all windows and doors have been replaced with double glazing.
It is warmer outside than indoors.
In winter months it is cold in here , I have central heating.
Any ideas how to get my home warmer.
diydoctor6
Re: Why is my house so cold, even in the summer months
by diydoctor6 » Wed Jul 20, 2016 2:51 pm
If your home is cold even when it is hot outside this suggests that the insulation is good; if it were too hot in the summer and too cold in winter this suggests that heat is being lost too quickly in winter and gained in summer. The insulation stops the heat entering in the summer, keeping your house cool.
If the insulation is good then you might want to look at the heating system to see if it is performing well.
Beyond this guess, with the little information you have provided it is really hard to say anything more.
If might be helpful to look through this project which helps you to diagnose faults with central heating systems:
https://www.diydoctor.org.uk/projects/chfaults.htm
Alternatively it might be helpful to see if all you radiators are working effectively:
https://www.diydoctor.org.uk/projects/ra ... oblems.htm
