Renewing cable to security and courtesy lights
the2ems
by the2ems » Tue Apr 03, 2012 11:18 am
I have a 100 watt security light and a courtesy light which were fitted by a previous owner. They have separate cables going to the supply. The wiring is a little untidy and conspicuous, so I want to renew it and re route it. Do I need to keep it as two cables, or could I run just one, first to one light, then from there to the second light?
jimmy_one_ball
Re: Renewing cable to security and courtesy lights
by jimmy_one_ball » Sat Apr 07, 2012 9:23 pm
Yes just one cable will be fine, 1.0mm is good enough to carry well over 6A even in the most onerous conditions (The circuit breaker rating must be 5/6A depending on the dvice). The switching arrangements will need careful consideration but you certainly don't need two seperate cables. Sadly this type of work will need certifying as a 'Minor Electrical Installation' with an inspection and various electrical tests required to verify the circuit is safe before any minor works can be carried out.
It is currently Sat Nov 16, 2024 12:20 pm
