Removing a cast iron soil pipe and replacing with plastic
andy hubbard
by andy hubbard » Fri May 04, 2012 12:37 pm
I have just seen the very good article on removing a cast iron soil pipe and replacing with plastic. How did the installers stop fragments of cast iron from falling inside the old stack?. Did they cut out a section at the bottom and then cover the hole?
plumbbob
Re: Soil Pipe
by plumbbob » Sat May 05, 2012 9:09 am
I'm not sure how your article showed the pipe being removed, but I usually dismantle the pipe in sections from the top, separating it at the joints. This way, no debris drops down inside the pipe.
It is currently Mon Jan 27, 2025 5:40 am
