Tapmate Futura tap
RichardM
Tapmate Futura tap
by RichardM » Fri May 11, 2012 2:56 pm
I have the above mixer tap in the kitchen, and it is leaking water at the base of the swivel. On pulling it apart I found 2 'O' rings. These have a square outer profile and I am wondering if this is how they are meant to be or is this just the result of wear. Nowhere seems to stock 'O' rings with the square profile so I need to know if the ordinary rings will do the job. Thanks for any help.
RichardM
plumbbob
Re: Tapmate Futura tap
by plumbbob » Fri May 11, 2012 6:48 pm
The square shape is simply wear and tear.
It is possible to find replacement rings but you will have a long search as there are so many different sizes.
RichardM
by RichardM » Fri May 11, 2012 10:59 pm
Thanks for the reply. I did wonder if it was wear. Shame two plumbers merchants didn't know either!! Just need to get the right sizes now.
RichardM
It is currently Thu Dec 12, 2024 10:39 am
