Re-wiring of a house
Kristian
by Kristian » Thu Jul 19, 2007 3:50 pm
Can anyone assist
1. What is the best cable to use to rewire a house?
2. How much cable will I require for a typical 3 bed house?
3. How much will it cost for hte materials?
4. How much would labour be (if I bought the materials myself)
Help is much appreciated
BLAKEY1963
Re: Re-wiring of a house
by BLAKEY1963 » Thu Jul 19, 2007 10:35 pm
[quote="Kristian"]Can anyone assist
Thanks[/quote]
KRISTIAN
CABLE TO BRITISH KITE MARK STANDARD AS SOLD
BY ELECTRICAL WHOLESALERS, IE B.I.C.C.
FOR A 3 BEDROOM HOUSE , WITHOUT KNOWING ,CIRCUIT
DESIGN , CABLE ROUTES LENGTH ECT HARD TO SPECIFY CABLE
QUANTITY.
MATERIALS WOULD AGAIN DEPEND ON TYPE OF SUPPLY,EARTHING,
DESIGN OF INTENDED INSTALLATION , NUMBER OF CIRCUITS ECT.
HARD TO QUANTIFY WITHOUT A SURVEY OF INSTALLATION REQUIRED.
LABOUR WILL DEPEND ON WHAT INSTALLATION IS REQUIRED AFTER
CONSULTATION WITH CLIENT , AND TAKING INTO CONSIDERATION
BS7671 AND PART P REGS.
I KNOW YOU REQUIRE AN IDEA OF COST , BUT THE WORK IS NOTIFIABLE AND A REGISTERED SPARKY IS REQUIRED TO DO THE WORK ANYWAY, AND CERTIFY , SO THE BEST WAY AROUND YOUR
QUESTION IS TO ASK ANY GENUINE REGITERED SPARK TO GIVE U A QUOTATION. I GIVE QUOTATIONS FREE WITH NO OBLIGATION AS DO
MOST BONA FIDE ELECTRICIANS.
BLAKEY1963
Kristian
by Kristian » Fri Jul 20, 2007 8:17 am
Cheers Blakey
I only need this info for a project I am completing for Uni. Its only so I can give rough costs for an experiment. I have proposed a ring main connecting isolator switches in each room of a house which are then connected to a radial circuit to the plug sockets in each room. (this allowing all the sockets in one room to be switched off using a single switch) I have said I will use PVC 2.5mm cable (with earth).
I have also said that 50m of cable will be sufficient.....can you tell me if ths is realistic or not?
Kristian
by sparx » Fri Jul 20, 2007 7:00 pm
Hi Kristian, Blakey may be busy so briefly, you can't do it using a ring main, it's against regs BUT if u ran a radial from 20A mcb from cu for each room with a 20A D-Pole sw, as used to control under counter skts in a kitchen it would be brill. & comply.regards SPARX
It is currently Tue Nov 26, 2024 11:55 am
