Shower plug
peterbrown
Shower plug
by peterbrown » Fri Mar 16, 2007 11:50 am
Please see additional information added to this question. Original question : "Is there a plug for use in a shower tray. It would have to sit on top of the waste outlet which is flush with the base of the tray, so preumably it would need to be heavy and have a seal ring on its underside".
I omitted to mention that this plug is needed for a shower waste that,for some reason, has been fitted to a bathtub- which does have an overflow fitted. I hope I don't have to replace the existing waste system (which is awkward to get at) - if I can find a plug that will work with the existing waste.
thedoctor
by thedoctor » Fri Mar 16, 2007 2:30 pm
no plugs made for this Peter as it would be far too easy for shower tray to overflow and cause major damage.
thedoctor
by thedoctor » Fri Mar 16, 2007 2:41 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sun Jan 05, 2025 5:22 am
