Aldi cement mixer - Instruction booklet
caspian
by caspian » Thu May 31, 2012 3:07 pm
Help, please! I've recently been given an Aldi cement mixer (Powercraft). It's a few years old but never been used. Unfortunately it is only partially assembled and there's no instruction booklet. I'm particularly unsure how the paddles attach to the inside of the drum, but there are other bits and pieces that I'm not clear on. Perhaps someone out there has a booklet that I could get a copy of...
Re: Aldi cement mixer - Instruction booklet
by welsh brickie » Fri Jun 01, 2012 7:41 pm
note the serial number and make, you should be able to get a copy online
caspian
by caspian » Sat Jun 09, 2012 1:55 pm
Thanks. However I tried that before posting the query. I've rung the contact number on the info plate on the mixer (which also has the model number) but, as it seems to be an older model, they had no information. I've also tried ringing an Aldi guarantee contact number but so far drawn a blank. I can't find any instructions on the web so I'm hoping someone out there as a similar model (I'm sure instructions for any Powercraft mixer would be useful to look at, even if it's not the exact same model as mine).
It is currently Mon Dec 23, 2024 1:39 pm
