two coats of finish
6 posts   •   Page 1 of 1
rnd
two coats of finish
by rnd » Sun Jul 22, 2007 2:41 pm
hi , just a question i am a little confused about . when skiming on to bord's, should two coats be needed does the second coat need to be mixed to the same consistancy as the first coat , or is it two different texture's
regards
Debbie
martin497
two coats or one...?
by martin497 » Wed Aug 01, 2007 5:22 pm
The correct way to skim is to use two coats of finish.
You can make the second coat to the same consistency if you want or you can make it a touch wetter if that feels better for you.
you dont need to make quite as much for the second coat either..!
rnd
by rnd » Thu Aug 02, 2007 10:54 am
excelent thank you martin
rambo77
by rambo77 » Tue Aug 07, 2007 7:49 pm
different people have different methods id mix the second coat just slighty wetter but maybe thats just me
damo
by damo » Tue Aug 28, 2007 12:14 am
2 coats allways but the second should be a tad wetter and only half as much needed as it goes further
rnd
by rnd » Fri Aug 31, 2007 8:20 am
cheer's guy's thank's
It is currently Thu Jan 30, 2025 12:04 am
