Hello! Hopefully someone can help
My CH and water has been off for about four weeks while some renovations have been done. This included replacing four radiators so required a drain and refill of the system. The CH is back up and running and all rads are piping hot however I get no water (either hot or cold) from the hot water taps.
The cylinder in the airing cupboard on the landing is hot - there's a couple of bleed valves close by which I've done - I just get water, no air. I've pumped mains cold back through the system using the cold-hot washing machine feeds 4 times for 30-45 seconds each time. This eventually fills the water tank in the loft and runs out of the overflow.
I've cycled the pump between high and low and cracked the top union nut on the cylinder (just get water)
Any suggestions would be greatly appreciated :o)
Regular copper cylinder
Small F&E tank
Baxi Solo 2 50 PF
Danfoss FP715Si timer
Grundfos pump
2 x Honeywell motorised valves
Gantry
