Shower cable size
chrissy
Shower cable size
by chrissy » Mon Jul 23, 2007 4:18 pm
I have had a new shower fitted and it state in the installation booklet the fuse should be a 38Amp fuse, it is a 8.5 shower so what is the recommended cable size for this fuse. The length from the MCB box to the shower is 35 feet, it is in conduit and I have a 6mm cable at the moment. Some people say this cable is ok others say it should be 10mm. I have calculated the voltage drop and that is coming out at 0.6% and I have been told it can be no greater thatn 5%. Can you advise me please?????
BLAKEY1963
Re: Shower cable size
by BLAKEY1963 » Wed Jul 25, 2007 10:59 pm
[quote="chrissy"]I have had a new shower fitted and it state in the installation booklet the fuse should be a 38Amp fuse, it is a 8.5 shower so what is the recommended cable size for this fuse. The length from the MCB box to the shower is 35 feet, it is in conduit and I have a 6mm cable at the moment. Some people say this cable is ok others say it should be 10mm. I have calculated the voltage drop and that is coming out at 0.6% and I have been told it can be no greater thatn 5%. Can you advise me please?????[/quote]
CHRISSY
SEE ANWSER ON 24 TH AND NOTE STEPHEN THE SPARKS
HELPFUL COMMENT.
BLAKEY1963
It is currently Tue Nov 26, 2024 2:36 pm
