Under Tub - outside all zones
7 posts   •   Page 1 of 1
misterg
by misterg » Mon Jul 23, 2007 9:23 pm
I've had conflicting advice on what can be put in under the bathtube. The sides cannot be removed without using a tool, so my understanding is this is outside all zones.
i'm lookin to get a shower pump fitted.
Can a socket be put under a bath for the pump, or should it be connected to an FCU outside the bathroom.
Also been told it can only be a low voltage pump - is this correct?
Mister G
BLAKEY1963
Re: Under Tub - outside all zones
by BLAKEY1963 » Mon Jul 23, 2007 11:53 pm
[quote="misterg"]Hi
MISTERG
IDEALLY ( OF COURSE YOUR PART P SPARK WILLADVISE )
I WOULD PUT THE PUMP UNDER THE BATH AND PUT THE
SUPPLY TO IT UNDER FLOOR BOARDSTO RCD SPUR OUTSIDE
BATHROOM. MOST OF THE THESE PUMPS ARE STEP DOWN VOLTAGES ANYWAY.
BLAKEY1963
Mister G[/quote]
misterg
by misterg » Tue Jul 24, 2007 12:50 am
Thanks Blakey.
If the ring main will be on the CU RCD, do I need another one, or will an FCU be sufficient?
Mister G
by sparx » Tue Jul 24, 2007 12:21 pm
Hi, guess BLAKEYS working !! HI, Hi,
yup if ring on rcd then just FCU suffices, but under current regs [this year anyway] must take 4mm earth from FCU to local pipes, & as most pumps are placky link across incoming to outgoing pipes, regards SPARX
Stephen the sparks
by Stephen the sparks » Tue Jul 24, 2007 9:20 pm
Under the tub is actually zone 0. Must be IPX7 protection, only 12v SELV equipment is allowed that cannot be reasonably located elsewhere.
No switchgear allowed in zone 0 I am afraid.
Regs 601-08-01 and 601-09-01 apply
misterg
by misterg » Wed Jul 25, 2007 12:33 am
[quote="Stephen the sparks"]Under the tub is actually zone 0. Must be IPX7 protection, only 12v SELV equipment is allowed that cannot be reasonably located elsewhere.
Regs 601-08-01 and 601-09-01 apply[/quote]
I thought Zone 0 was in the tub and if you need a tool to remove side of tub then it is outside all zones.
Is this not correct?
Also what is IPX7?
G
misterg
by misterg » Wed Jul 25, 2007 12:39 am
[quote="sparx"]Hi, guess BLAKEYS working !! HI, Hi,
yup if ring on rcd then just FCU suffices, but under current regs [this year anyway] must take 4mm earth from FCU to local pipes, & as most pumps are placky link across incoming to outgoing pipes, regards SPARX[/quote]
Cheers Sparx
Great that was what I was hoping for.
I'll make sure the electrician fits the 4mm earth too.
Regards
G
It is currently Fri Nov 22, 2024 2:41 pm
