Unusual Gas BBQ Fittings
MustangTC
by MustangTC » Mon Jun 11, 2012 1:19 pm
Hello,
I have a BBQ that I cannot return which has unusual gas fittings and missing parts.
Simply the bbq is a two burner with 1 side burner. The LPG would connect via an 8mm hose to the side burner however the hose and connector are missing. The Connector from the side burner is a CGA 180 .625" right hand male so I would need the same but female. British standard 3/8 etc do not fit gas tight and are usually left hand thread.
I need a way to attach a hose to this fitting either via a (fulham) nozzle with jubilee clips or a hose which can screw onto the unit but I cannot find anything.
I've been to numerous specialists in my area but am totally stuck.
Please help!
Cheers,
MustangTC
It is currently Mon Jan 06, 2025 8:43 pm
