Best way to level/line up Steel Beams
6 posts   •   Page 1 of 1
bob_5795
by bob_5795 » Thu Jun 28, 2012 9:20 pm
I'm starting a loft conversion.
I have 5 floor steels to bear on concrete lintels (used as padtones).
The house is a brick built 1930's semi.
What is the best method for ensuring all lintels/steels are level.
Thanks.
Re: Best way to level/line up Steel Beams
by welsh brickie » Fri Jun 29, 2012 9:16 am
use a string line to line them up, and a long straight edge (4x2 or similar) with a spirit level to check for level.
bob_5795
by bob_5795 » Fri Jun 29, 2012 4:04 pm
I've tried using a string line when laying blocks, found it a very awkward and finicky way to work.
I have a cheap laser level, but again find it difficult to work with, how can you trust the bubble in the level is going to be accurate over the 6 metre span I have to work with.
I have thought about using a thin see through flexible pipe and using water inside, however its placed one end should in theory level up with the other ... anyone had any experiences ?
by welsh brickie » Fri Jun 29, 2012 7:22 pm
a water level can be used and is accurate.
bob_5795
by bob_5795 » Thu Jul 05, 2012 9:57 am
Thanks.
I'm just wondering what the pro's would use.
Looking at this product:
http://www.screwfix.com/p/water-level-kit-10m/18133
It appears that its impossible to use as is for low level work - like paving stones, this would also apply to my job as the bottom of the padstone is just 75mm above the lowest level I can work at. I guess a work around would be to attach the top of the level to a piece of wood and mark it with a scale going down, so the top of the level can sit above the work area.
Seems crude, but should get mm accurate - I guess a floor thats with a few mm in each corner is pretty good.
by welsh brickie » Thu Jul 05, 2012 9:17 pm
hire a rotary laser if your conserned about accuracy.The laserbeam can mark a level line on the wall and you can measure up to the steel.
It is currently Tue Nov 26, 2024 3:54 pm
