Do they still make larger wc pans. (Like the old ones)
collectors
by collectors » Sun Jul 08, 2012 10:18 am
Hi, we have quite a long run of pipe from the wc to the main drain & would like a loo that will flush with more water. The long run is because there used to be a septic tank on the house & at some time the pipe was diverted to the neighbour’s main drain.
Do they still make the larger capacity wc’s pans & cisterns that will hold more water to enable a better flush.
Normally the pan is matched to the cistern to stop it over flowing the pan encase of a blockage. So I don’t want to just increase the cistern size for extra water.
Any makes would be a help.
The larger cistern could be made up at worst.
Chris
Re: Do they still make larger wc pans. (Like the old ones)
by stoneyboy » Thu Jul 12, 2012 11:15 pm
collectors,
If you want a more forceful flush and you are not happy with the full flush option supplied on many WCs these days I can only suggest you go for a high level cistern.
BuyersAssistant
by BuyersAssistant » Sat Sep 01, 2012 10:55 am
Yes,
I would have a browze around DIY store websites etc. see what you can find, plumb centres etc. They are normally very helpful in these places.
Failing that a reclaimation yard may have an old style toilet.
It is currently Tue Nov 26, 2024 2:26 pm
