possible lighting circuit overload?
melvin
by melvin » Thu Jul 26, 2007 5:37 pm
I am thinking of installing 10x50w mains halogen downlights in a bedroom.
My house has only one lighting circuit. There are 11 light fitments connected to this circuit. Some with multi halogen bulbs, others with multi 60w golf ball bulbs.
Am I in danger of overloading this circuit? What problems if any will it cause?
by sparx » Fri Jul 27, 2007 9:09 am
Hi melvin, yes you are but to be sure add total watts of all fittings ,
divide number by 230 to find total Amps you could draw if all on together.
if on mcb then it will trip after a while if over its rating, if on rewirable fuse it will get very hot, then eventually melt.
1.0mm cable rated for 11A in best circumstances [less if in insulation]
1.5mm " " 15A " " " " "
regards SPARX
melvin
Will i be overloading the circuit (part two)?
by melvin » Sat Jul 28, 2007 6:37 pm
Thanks for the swift reply.
My total watts including the new Halogen lights comes to 1734w Which gives me a total of 7.5 amps. Well within the amp rating of the cable.
As my lighting MCB is the normal 6amp. Will I need to upgrade this to a 10amp?
by sparx » Sun Jul 29, 2007 9:05 pm
hi melvin ,
Probably not as it's unlikely [unless u got teenage kids] u will have all lights on together! If u find mcb trips occasionally then uprate to 10A.
I had this situation & decided to not uprate, everyone soon learnt to turn off lights not needed!!!!
Ignore anguished cries of 'turn off the lights' from around the house.
Regards SPARX
It is currently Sun Nov 24, 2024 7:46 am
