Removing cast iron soil pipe extension
bemused
by bemused » Thu Aug 02, 2012 7:25 pm
I'm hoping to fit a new low-level, close-coupled toilet and need to remove a short extension that is in place that used to couple with the old pan. The soil pipe and extension are both old style cast iron and when I started to dig out the putty-like filler at the joint I seem to have hit what looks like solder.
[attachment=0]IMG_1880x.jpg[/attachment]
The picture shows joint with extension piece covered by plastic bag.
It's starting to look like a tricky job to get this extension out and I'd be grateful for any advice.
Cast iron extension to old toilet outlet
plumbbob
Re: Removing cast iron soil pipe extension
by plumbbob » Fri Aug 03, 2012 2:32 pm
The extension pipe is most likely to be a lead pipe. Break the putty out and remove the lead pipe section.
Clean the joint and replace with plastic pipe using clear silicone as a sealant.
It is currently Fri Nov 22, 2024 6:50 pm
