kitchen cupboard door adjustment
goof
by goof » Sat Aug 11, 2012 5:43 pm
Having used up all the adjustment on the hinges my door still needs to move towards the hinge edge by about 3 mm. Can one obtain thinner carcase mounting plates?
Thanks for your help.
Geoff.
toptips
Re: kitchen cupboard door adjustment
by toptips » Sun Aug 12, 2012 1:22 am
Hi Geoff,the screw that connects the hinge arm to what you call the mounting plate could be restricting further adjustment if it is too tight,try and loosen it a touch and see if this helps any and then tighten back up.
terryleth
by terryleth » Mon Aug 13, 2012 7:57 am
Your kitchen cabinets will be tight initially when you use it it will become loosen. If still its causing you a problem try opening it closing it for sometime continuously it will become a bit loose but not much.
terryleth
by terryleth » Fri Aug 17, 2012 7:20 am
Has your kitchen cupboard door problem solved?
goof
by goof » Fri Aug 17, 2012 9:31 am
No solution yet, I still think a thinner mounting plate is the answer, or else I chisel out a 3mm deep recess in carcase end panel and sit the plate into it.
Thanks for all the answers so far.
Geoff.
It is currently Thu Dec 26, 2024 12:27 pm
