Polystyrene panel insulation
ClareS
by ClareS » Mon Oct 01, 2012 9:59 am
We are renovating an add on building which is used as a bathroom, it is built of concrete blocks. Having stripped out the old plaster board we found 80mm thick polystyrene panels used for insulation. I want to replace these, but thinking of using panels of only 40mm thick, so as to keep the room as big as possible. Will using thinner panels make a huge difference to the insulation, or am I worrying about nothing.
Any advice or comments would be most welcome.
Re: Polystyrene panel insulation
by welsh brickie » Mon Oct 01, 2012 5:48 pm
there are various types of insulation that are thinner and more efficent,try googling "tri iso super 10".www.kingspaninsulation.com is another also www.expandingfoamkits.co.uk.
PanelSystems
by PanelSystems » Thu Oct 11, 2012 11:01 am
If you were to use Styroliner there would be a small reduction in thermal value with the reduced thickness, but at a like for like thickness, Styrofoam is more thermally efficient and it has the added benefit of acting as a vapour barrier.
More info can be found at http://www.styroliner.co.uk but feel free to post here if you need any further help.
It is currently Mon Dec 23, 2024 10:04 am
