Loft insulation
JHJS
Loft insulation
by JHJS » Thu Oct 04, 2012 12:59 am
I want to increase the depth of my loft insulation to 270mm, however, when I've looked at what's already there, it appears that the joists are 2 and a half inches deep with 2 inches of insulation laid between them. Everything I've read suggests that joists are always 4in deep? Do I need to raise the level of the joists, or can I put 4in insulation between the joists and then more at right angles across it? Would I be better leaving the original insulation or replacing it?
Re: Loft insulation
by welsh brickie » Thu Oct 04, 2012 4:04 pm
2 inch deep joists ? anyway lay the insuation ontop and across the joists leave in whats there.
It is currently Mon Dec 23, 2024 8:55 am
