New boiler fitting
tumbleweed
New boiler fitting
by tumbleweed » Fri Oct 26, 2012 3:21 pm
I'm looking at purchasing a BAXI BERMUDA HE BBU BOILER.. I have at the minute a Baxi 552 (very old) and was wondering if the change would be straight forward, ie.. pipeworks and outlets..
Re: New boiler fitting
by htg engineer » Fri Oct 26, 2012 9:43 pm
It wont be a straight swap, as your current system is probably gravity HW. You will need to change to fully pumped or sealed system. You need to install condensate pipework, which you don't have now. Then you need to install the flue/liner and flue terminal. You'll more than likely need a new cylinder/tank. It will be alot more expensive than a combi boiler, is there any reason that you don't want a combi?
htg
tumbleweed
by tumbleweed » Sat Oct 27, 2012 10:39 pm
I don't have anywhere to put the boiler ie an outside wall that's free..
I have instead purchased a 3yr old Baxi gas fire and boiler - Baxi Bermuda 50/6.. How easy will this swop be?! I'm hoping it's very similar to the one I have already..
Cheers..
It is currently Sun Dec 22, 2024 3:00 am
