magnetic seals in showers
johnthemail
by johnthemail » Fri Oct 26, 2012 6:30 pm
I recently had to remove the black magnetic strip in my shower door. The strip is attached directly to the door. It is 7mmX4.5mm with a small flange. I am able to modify it slightly. Where can I get such an item.? I am aware I will probably have to but a pair as there is a polarity problem as the top surfaces must be opposite poles.
It is currently Fri Jan 10, 2025 7:45 am
