Joining wires together to reach fuse box in new location
bulgariasteve
by bulgariasteve » Sat Oct 27, 2012 6:21 pm
I own a house in Bulgaria and I have had to move the position of the fuse box and replace with a new "Trip Switch" box. There are approx 12 pairs of wires that need to be extended to reach the new box. Is crimping with the correct size of crimping terminals the best way of joining these wires to new lengths of wire or is there a better way? Thanks Steve
kbrownie
Re: Joining wires.
by kbrownie » Thu Jan 24, 2013 8:03 pm
Crimping with good quality ratchet, crimps are sized for cable and heat shrinking joint.
This will give good contact of conductors joined and the heat shrink will help support and maintain the joint, from any additional stress.
bulgariasteve
Re: Joining wires.
by bulgariasteve » Sun Jun 02, 2013 9:36 pm
Thanks for your reply. I have just returned from the house and have found that the wiring used is all 4mm solid cable. I thought about using wago terminal connectors but all the info suggests that they can only be used up to 4mm stranded and 2.5mm solid. So are 4mm crimp connectors the only option?
The wiring is being extended by approx 2 feet. Thanks. Steve
Reevio
Re: Joining wires together to reach fuse box in new location
by Reevio » Fri Aug 08, 2014 8:00 pm
Junction boxes screw to a solid bit of timber will be fine
It is currently Sat Nov 23, 2024 5:07 pm
