I am replacing an old dial honeywell room stat (42003840-001) with a digital DT90E.
I am unsure about the wiring compatibility and wondered if someone could clarify please?
Currently, I have 3 wires - Blue, Yellow and Red.
The blue is inline with a resistor and then tied to the yellow, which is then connected to what I assume is the thermistor. Indicidentally, Blue is in terminal no.2 and yellow in no.3.
The red wire is in terminal 1 and this runs to the other side of the thermistor.
The new unit has three terminals only, A which is marked as Live, B which is marked as neutral via a resistor symbol and C, which is not marked but on the diagram, it looks like it is internally connected via a switch to A.
Question being, where do my Blu, Yellow and Red wires go on the new unit?
Any help would be most appreciated.
Thank you,
Sean.
