hot water tap
rickqrp
hot water tap
by rickqrp » Fri Nov 02, 2012 10:22 am
hi everyone,
my hot water tap in the bathroom is playing up, when turned on nothing happens,when you lift tap top up water comes out ok? any answers
thanks
Re: hot water tap
by htg engineer » Sat Nov 03, 2012 9:33 pm
Isolate the hot supply and strip the tap, you'll probably find the tap washer or jumper has come off. Replace or re-assemble.
rickqrp
Re: hot water tap
by rickqrp » Sun Nov 04, 2012 10:23 am
cheers for reply,called in plumber he said it needed new tap,@god knows what cost.thanks for use of forum.
rickqrp
Re: hot water tap
by rickqrp » Wed Nov 07, 2012 6:29 pm
hi,
just to let you know managed to fix tap,it was missing a small copper clip at top of barrel,it held it all together when you opened tap.so much for the plumber i called in.won't ever ask him back...
It is currently Fri Jan 10, 2025 7:13 am
