Can I put a tumble dryer under stairs with fuse board?
catdavis
by catdavis » Fri Nov 16, 2012 8:57 pm
Does anyone know if it is safe to put a condensor tumble dryer in an under stairs cupboard which also houses the fuse board?
There is sufficient room & I will put a vent in the door to help with condensation but it will be sited under the fuse board.
Re: Can I put a tumble dryer under stairs with fuse board?
by htg engineer » Sun Dec 02, 2012 7:18 pm
The likelihood is it would be okay, as long as the water tray is emptied regularly. However it is an expensive risk, if a seal goes or something goes wrong and alot of moisture gets into the mains board it may - at worst - require replacing. They are relatively cheap but it's the inconvenience of having no electric and the time/labour costs of having it replaced/repaired. I would find an alternative location.
htg
It is currently Fri Nov 22, 2024 5:07 pm
