plaster splashes on brickwork
tooly
by tooly » Sun Nov 18, 2012 9:28 pm
Hi, need some advice on how to remove some plaster splashes from house brick surface. It's a small area of about 1sq mtr, which i want to be left exposed for effect above a wide entrance door. This area of brickwork is internal. If i found any mortar splashes what method could i use to remove these. Thankyou for any advice. Tooly.
Re: plaster splashes on brickwork
by welsh brickie » Mon Nov 19, 2012 10:16 am
you can use a brick acid to remove stains,most builders merchants stock it.
It is currently Fri Nov 22, 2024 4:41 pm
