strange lighting ring wiring
Cheshire Taurus
by Cheshire Taurus » Sat Jul 28, 2007 6:32 pm
I moved into a brand new property and have started replacing some of the light switches with dimmers. when I removed the old switches I was supprised to find that the lighting ring was taken to the switch rather than the ceiling rose. to put it another way for a single gang switch 3 twin+earth cables go to the switch 2 for the ring and one going to the ceiling rose with the 3 earths and 3 neutrals joined in a loose terminal block in the back box.
Is this a normal way to wire the circuit? if not is it legal?
I always thought the ring went to the ceiling rose and a single cable to the switch.
BLAKEY1963
Re: strange lighting ring wiring
by BLAKEY1963 » Sun Jul 29, 2007 12:24 pm
[quote="Cheshire Taurus"]I moved into a brand new property and have started replacing some of the light switches with dimmers. when I removed the old switches I was supprised to find that the lighting ring was taken to the switch rather than the ceiling rose. to put it another way for a single gang switch 3 twin+earth cables go to the switch 2 for the ring and one going to the ceiling rose with the 3 earths and 3 neutrals joined in a loose terminal block in the back box.
I always thought the ring went to the ceiling rose and a single cable to the switch.[/quote]
CHESHIRE TAURUS
IT CAN B WIRED THIS WAY. CONNECTIONS SHOULD BE INSULATED WITH TAPE WHERE NOT IN TERMINALS.
BLAKEY1963
julianevans11
by julianevans11 » Sat Aug 04, 2007 10:08 am
It's not illegal. It just makes more accessible to remove the switch rather than get up to the ceiling rose should a fault occur. In my experience it's usually used with light fittings that may be difficult to install.
It is currently Mon Jan 13, 2025 2:27 am
