Storage Heater - charging rate
NEC
by NEC » Sat Dec 15, 2012 11:58 pm
My one storage heater Dimplex is not getting hot as expected. Relatively new bought second hand. I am monitoring the charging rate and it seems to be spending more time off than on - is that right? I would have thought that it would be running a continuous charge till it was full and pretty much 'red hot'. any thoughts please? thanks.
Re: Storage Heater - charging rate
by ericmark » Sun Dec 16, 2012 8:53 pm
I used one to test iron laden concrete blocks with idea of using them to replace the clay ones used. The one I had would go on until the temperature set before starting to cycle off and on which would takes quite a few hours.
However it took quite a time for the heat to start coming out so how one would know when at the 900 odd degs C it reaches I don't know.
At 1/2 hour we had problems as water started to be expelled from the bricks so clearly at 1/2 less than 100 degs C. While I was working on project cure was not found seemed there was a chemical change and however long we left new bricks water came out. Once heated first time even if soaked again there was not a problem. But to heat to over 350 degs needed to ensure full chemical conversion would cost more money than saved using cement instead of clay so think idea was shelved.
It is currently Fri Nov 22, 2024 10:38 am
