Best way to cut close to a wall
alanj
by alanj » Mon Dec 17, 2012 1:53 pm
Hi, I am replacing my chipboad flooring with ply. But some of the stud walls are built on top of the flooring so that section can't be removed. I want to cut the chipboard as close to the wall as possible - what is the best way to do this?
I've found some Exakt mini saws which look nearly the right tool, but they have limited depth of cut ( 12mm ) and can not cut into corners or even close to in some directions due to the "handedness" of the handles.
I've previously tried using a hand flooring saw, but frankly that took forever.
Is there anything else out there that might do the job?
Alan
Re: Best way to cut close to a wall
by welsh brickie » Tue Dec 18, 2012 8:18 am
you can hire a sabre saw,its also called a reciprocating saw.
It is currently Fri Nov 15, 2024 9:34 am
