Mounting TV on stud wall
ennaress
by ennaress » Thu Dec 20, 2012 3:04 pm
Santa is bringing me a new 32" / 10kg TV which I intend mounting on a bracket on my stud wall. What are the best fixings - hollow wall anchors (are they supposed to be driven through the plasterboard and actually into the blockwork?) or SD Metal Rawls? There's not enough of a void for the toggle spring type. Happy Christmas! Cheers
Re: Mounting TV on stud wall
by stoneyboy » Thu Dec 20, 2012 5:54 pm
ennaress,
From your description I guess you are talking about a dry-lined wall.
In this is the case and you are fitting a tilt and swivel mounting go through the plasterboard and into the blockwork for secure fixing. You may need to inject foam between the plasterboard and wall so to support the board.
If you have a stud wall and are using a fixed mounting the corkscrew fixings should be fine but use every available mounting hole in the brackets.
ennaress
by ennaress » Thu Dec 20, 2012 6:35 pm
Cheers!
Actually, it's just a flat mount, not a swivel one and I'm pretty sure it's a stud wall given there's strips of wood every 400 or so vertically.
Thanks again
It is currently Mon Dec 23, 2024 10:44 am
