Basement Tanking: What Level of Waterproofing do I Need?
GARYM123
by GARYM123 » Sun Dec 30, 2012 4:52 pm
Hi there,
new to the forum so bear with me :-)
I have recently aquired a large basement below my ground floor flat and intend to convert into the space making the property split level.
The basement looks and feels very dry and with enough head height no need for excavation.
My question is in relation to what level of waterproofing i will need...
The property appears to have been externally tanked when constructed with an asphalt coating.
Is this sufficient to keep the basement dry? I would obviously slap on some waterproofing paint or something similar as well.
Many thanks
GetAttachment (1).jpg (10.78 KiB) Viewed 3041 times
Re: Basement tanking
by welsh brickie » Mon Dec 31, 2012 10:10 am
looks like water in the middle of the floor. you could have ashphalt laid on the floor paint the walls with aquapruff buitumin paint or similar, and or batten the walls and use pvc cladding
It is currently Fri Nov 15, 2024 6:39 am
