Hi All,
I want to build a simple shower system using a platic drum connected to a single impeller pump which will then connect to the shower unit. All are to be located in the bathroom. So it's simply ambient water stored in the drum which is pumped to the shower. It's an idea I've had and would like input from plumbing experts whether this is achievable and safe to do.
Why do I want to do this? I'm an expat working in middle east. The water out here is stored in tanks on open flat roofs. As you can imagine, it becomes extremely hot and cannot be used for showers most of the day. I wanted to overcome this problem by finding a solution of my own.
Thanks for any positive advice.
