Concealed Hinge
lorraine7045
Concealed Hinge
by lorraine7045 » Sun Jan 20, 2013 9:31 am
I have cut down a kitchen cabinet door and need to make a hole to insert a concealed hinge.
I don't know how to do this. Do i need to use a drill with a forstner bit or a router?
The door is made of 18mm MDF.
rapidkirk
Re: Concealed Hinge
by rapidkirk » Tue Jan 22, 2013 4:43 am
You can make a hole, with either a 26mm or 35mm hinge cutter http://www.rapidtoolsdirect.co.uk/category/router-cutters-worktop, it can be used in a drill, but make sure you don't go too deep.
It is currently Fri Jan 10, 2025 9:42 pm
