Inset stove chimney breast
softy1990
by softy1990 » Sun Jan 20, 2013 11:49 am
I fitted a Invicta 700 mutli fuel inset stove into an existing chimney breast with a flexible flue, closure plate and cowl. Although I have used heat resistant cement and plaster around the surround of the stove I have noticed that immdiately above the stove where the chimney breast gets hot the plaster is cracking, any ideas how to solve this issue, should I have used heat resistant cement and plaster on the entire chimney breast! I didn't because I was advised that I could of just used cement render with finsih plaster but I didn't know whether that was correct, any ideas please, thanks.
2tellytel
Re: Inset stove chimney breast
by 2tellytel » Fri Jan 25, 2013 5:49 am
This may not be the answer you want to hear, however I have a small stove (puffin) and I had similar problem
I decided to chop away the plaster to reveal the brick work, then I made sure it was well pointed up.
You can leave this bare brick or paint I decided to paint
Apart from repainting now and again(I use masonry paint) when doing general decorating it has been fine.
I do however live in a cottage and the exposed painted white brickwork with a black stove looks in keeping.
Hope this helps
by welsh brickie » Fri Jan 25, 2013 12:16 pm
you can drylıne the brestıng wıth a foilback plasterboard to reflect the heat
It is currently Fri Nov 15, 2024 6:21 am
