by ericmark »
Tue Feb 12, 2013 9:46 pm
OK dichroic means that light is reflected but heat goes through the reflector so the item the light is pointing at does not over heat. With LED you can forget it as so little heat generated. I have just got some 9 LED MR16 0.58W/12V lamps for my bathroom from Pound World sure you can guess the price each. However these are very low power lamps and with the GU10 version of the same lamps they will not switch off. They go very dim but not off.
If the supply for the MR16 lamp is from a simple transformer as in my case no problem but if an inverter is used then likely these would be too small.
So really you have to find the dropper box and read the info on the box. As already said if there is a minimum then likely you can't use LED. A good indexation is real transformers are large and heavy but inverters are small and light.
Although you can replace the inverter for an LED driver likely best option is to change to GU10 instead of MR16 and feed the lamp with 230v instead of 12v this will also mean cold cathode can also be used.
