Internal bricks
tooly
Internal bricks
by tooly » Wed Feb 13, 2013 8:12 am
I have cleaned about a square meter of internal house brick using a brick acid. I am using this area as a feature, and the bricks came up really clean and looked good. The appearance was enhanced because I had washed the residual acid off the area and the wall was still damp. Can I reproduce this appearance using a brick sealant, and if so what type. The area is internal and would a brick sealant peel over time? Thanks Tooly.
Re: Internal bricks
by welsh brickie » Wed Feb 13, 2013 6:32 pm
you can spray it with a silicone sealant or use a pva solution or a clear varnish try a small area to see whats best
It is currently Fri Nov 22, 2024 4:36 pm
