Curing a leaky soldered joint.
paulbentall
by paulbentall » Wed Feb 20, 2013 8:18 pm
Is there any way of stopping a drip on a soldered joint other than taking the joint apart and starting again.
Re: Curing a leaky soldered joint.
by htg engineer » Thu Feb 21, 2013 1:10 pm
If the fitting is on a horizontal piece of pipe then No - is the short answer.
If vertical pipe then you just need to drain the water and reheat, adding a little fresh solder.
If it is horizontal pipe you'll need to cut the pipe to get the water out otherwise you'll never get a good joint.
htg
It is currently Fri Jan 10, 2025 7:27 am
