Rules for studs
Ask questions and find answers on a range of subjects relating to self build projects
Nigel_T
Rules for studs
by Nigel_T » Tue Apr 09, 2013 10:51 pm
Hi All
I'm having a wooden kit built at the moment, its quite small and has two internal partitions that are not load bearing. My question is regarding the studs that make up the external walls, can they be drilled though to allow passage of pipework, cables etc? I have plenty of guidance on notching and drilling floor joists and not to cut into rafters, but what are we allowed to do with the studs that make up the external walls?
Regards
Nigel
balege
Re: Rules for studs
by balege » Thu May 22, 2014 8:55 pm
You need to treat them more or less the same as you would floor joists. Any notches will affect the structural strength of the timber. They may not be load bearing but they will form part of the structure. Usually I would drill centrally at about 200mm from the base. This should be about the right height for your sockets.
It is currently Sat Nov 23, 2024 9:18 am
